p8z77-m pro stops reading hard drives
jigglywiggly
30
okay this is VERY anoyying
so if i have my computer up and running it's ifne but sometimes or 90% of the time on boot
my computer actsl ike it's working then slowly freezes
it's like if you unplugged a HD
i have 2x120gb ocz vertex 3's in raid 0
you might be thinking "OCZ, game over"
but i had 0 problems on my asrock p67 extreme4
i am on the latest bios, any ideas?
2600k
EDIT: seems to be related to OC. Which is strange since if it doesn't freeze, it doesn't crash on prime95.
That's if I get that far.
Anything past 4.4ghz is so unstable.
I couldn't get past 4.4ghz on my old asrock p67 extreme4 either.
my 2600k is awful : /
1.405 volts with load line calibration set to "High". If it's on auto, I get bsods.
This is at 4.4ghz lol
Built in profiles don't even load the windows logo
same thing with my old asrock
I got literally the worst 2600k ever made
EDIT: or maybe it doesn't I think it freezes if I load cpu-z
like just on my desktop I loaded cpu-z, and bam my computer froze.
T_Yamamoto
15,007
795
Your using the built it oc system correct? That usually feeds too much volts. So do it by yourself and see if that gets stable.
jigglywiggly
30
nah, all the volts on manual
here are the volts on my old asrock board for 4.4ghz
if you see anything way out of wack, please do tell
https://dl.dropbox.com/u/46294175/gamespot/20120908_184832.jpg
nevermind i got my cpu to 4.6
1.420 volts with load line calibration set to extreme so that's about 1.47 volts according to cpu-z right before it freezes my computer
my 2600k is poop
temperature on intel burn test is only 98c
umad 2600k? (any less volts is unstable)
