- Dec 14, 2011
- 4
- 0
- 0
I'm new here. I am not an experienced in hardware, at least not to a degree I see in other people's posts.
Here is the problem.
I have a new system with ASUS P8Z68-V-Pro motherboard.
As I have a 27" DELL monitor, on-board graphics did not support the max resolution, so I have additionally purchased GIGABYTE GV-NX86T256H GeForce 8600 GT 256MB 128-bit GDDR3 PCI Express x16 video card.
The problem, that I later traced to a card, was that USB3 ports worked only sometimes. I could not spot a pattern, not at first.
I got my MOBO replaced, by another one just like the first one.
That time USB3 did not work at all.
I took it back to the store, and USB3 worked there. So, being hardware-challenged person, I just bought new keyboard and mouse, made sure they worked in store, came back home, plugged it all in, USB3 does not work.
I then removed the graphics card, and connected VGA to the monitor.
All of a suddent USB3 works again.
So I installed another card, this time ASUS EN210 SILENT/DI/512MD3/V2(LP).
USB3 does not work.
Both cards were connected to the first (top) blue slot.
Both cards work fine video-wise.
I have installed the latest BIOS using ASUS suite's Update utility.
I have installed all the latest drivers, though it is not clear to me how drivers should make any difference, the USB3 working/not working is seen at the bios stage, before the OS booted.
Since for regular work resolution is more important then USB3, I'll have to install the card back, but I am very frustrated with having to wait longer when copying large files between USB3 external drive and my home and office machines.
Stops working means - usb mouse does not work, HD gets powered but not seen by the system.
Any idea what I should try?
USB3 does not work.
