Hi everybody.
I have some problems with my p8z68 v pro motherboard. (I suppose the mobo is the cause!)
My system:
i7-2600k (NO Overclocking)
P8Z68 V PRO (because of the critical errors, I updated to 0501 version, but still no luck)
GSKILL RIPJAWS F3-12800CL9D-4GBXL ;they are 2x2GB sitting in DIMM A2,B2 as per mobo instruction
stock air cooler
Sapphire HD4690 1GB
WD Black, Sata, 500GB
PSU 1000W
now the problem is i get reboots in widnows 7 and even in the bios environment.
I windows 7, it just happens occasionaly but in bios, it is more likey to happen.
As per GSKIL support forum thread I enabled XMP and put the dram voltage to 1.5V (The voltage fluctuates between 1.518~1.523V, I do not know if this is normal!)
Also, in the win environment, everytime the system reboots, it logs CRITICAL ERROR as following :
Microsoft-Windows-Kernel-Power
EventID 41
I did MEMTEST and MEMTEST86 with no errors. I did some other test, no problem.
I wanted to be sure of my cpu, so I did some cpu benchamrks to put it under perssure.
So, I ran prime95, I noticed very high temperatures at 90C (82C in the evening actually) when running its most cpu intensive torture test.
other than that, the system is usually 38C in idle and 40~45C when doing most daily stuff.
My room temperature is around 27C.
Somewhere i read that cpu might not get the required voltage, so I picked up some sensor info from asus probe:
The voltages are:
in IDLE mode:
V Core: 0.832V, +12:12.384V, +5V:5.22V, +3.3V: 3.376V
Also the ASUS TuboV EVO says;
BCLK freq: 100.3MHZ, CPU Voltage:1.6V, DDR Voltage:1.5V, VCCIO: 1.05V, CPU PLL: 1.80V, PCH:1.05V, all the others are 0.5V
In Prime 95 torture test mode:
V Core: 1.248V, +12:12.384V, +5V:5.22V, +3.3V: 3.36V
BCLK freq: 100.3MHZ, CPU Voltage:1.65V, DDR Voltage:1.5V, VCCIO: 1.05V, CPU PLL: 1.80V, PCH:1.05V, all the others are 0.5V
I once set windows to SLEEP mode. But when I wanted to wake it up I did several reboots to be able to wakeup the system.
Please help.
Thank you.
My system:
stock air cooler
Sapphire HD4690 1GB
PSU 1000W
EventID 41
The voltages are:
in IDLE mode:
Please help.
Thank you.
