- May 16, 2002
- 27,427
- 16,293
- 136
OK, so all of a sudden I could not click on a file without locking up, then tried to re-install, and would not even get into install. Then tried disconnecting all the HD's but one. No go, so bad HD ? used an external adapter to disk check. Took 5 hours. No go after that, but checked good. Then a different HD from a functioning computer. No go, won't even get close to beginning setup, when it says "starting windows" before you even get the setup option, it BSODS. 7A I think it was, which say something about disk problems.
Could the sata ports all be borked from back when there was a known sata bug ? its about 6 months old.
