Long time lurker, first time posting... like a lot of other guys
Anyways, I have an issue with this motherboard: cold-booting. By this, I'm talking about the part where you press the power button to activate the motherboard -- this part is somewhat slow.
To give you an idea, my last build (775) would boot up instantaneously -- once you press the button, the motherboard turns on. For this new build, however, the motherboard turns on a second after you press the power button -- it's delayed compared to my previous build.
Other than that, my computer's running fine, so I should have all the connections in the right spots. I also updated the BIOs to the latest.
Just wondering if there's a way to fix this? I couldn't find any solution (maybe I'm using the wrong terminologies) to this...
Other than that, my computer's running fine, so I'm assuming that I plugged everything at the right spots..
Thanks!
Thanks!
