P6n-sli-platinum audio jack problem
munisgtm
Hi guys!
for some time i am having problem with the my mobos sound output , that is when i insert the pin fully into the audio jack it gives output to only one of the speakers and when i slightly pull the pin out it gives output on both of the speakers but the volume goes down then! What could be the problem ? any solutions ?
My rig is :
e4300 @ 2.8 (stock HSF)
P6N-sli platinum
Corsair 2x1GB DDR2-667 Value RAM
8800GTS320mb
Cooler master 600W power supply
Thanks in advance!
Sounds like the Jack itself has issues. When you have the plug in partially like that you are forcing the one chennel that does work to make contact with both sections at the end of the jack so that both speakers ore pushing out audio from the one chennel. In a sence it a make shift Mono connection. The volume drops because the signal is split in half between the 2 speekers. You best solution may be to buy a cheap sound card. Other wise you could try resoldering the jack to the motherboard or just out right replace it. Another option would be to use the motherboards front panel audio connection. Just be careful about volume since the front audio goes threw a pre amp of its own before the sould is outputed to the headphones/speakers.
i tried to hook up the front panel audio but its not working at all! i checked the mobo-casing connections but still not working! On my mobo there is JAUD1 connector for it has these pins 1.Mic L 2.GND 3. Mic R 4.Presence 5.lineout R 6. MIC_JD 7. Front_JD 8.NC 9.Lineout L 10.lineoutJD and the wires coming from the case are mic-power,mic-in,gnd,lineout R,lineout L is some wire missing from the casing ???
No. Stereo plugs have a center ring for one of the channels and the tip is the other channel, with the back end of the jack being a common ground. If it were somehow possible for the tip (or center ring) to touch both jack connections, the jack outputs would be in parallel. This would lower the impedance seen by the preamp (typically 47k ohms) resulting in an impedance mismatch. A lower impedance would overdrive the preamp, but for stereo applications it would work at the same or higher volumes, albeit with some possible distortion.
Since the OP is using speakers, his setup has a preamp and a power amp. If he has powered "PC" speakers, the amplifier sections are built in to his subwoofer. The volume control attenuates the signal in the preamplifier section, but the power amplifier produces the volume level required to drive speakers.
Being mechanical parts, jacks fail, sometimes from abuse or over use. Typically, the contacts become oxidized or just plain dirty - a squirt of contact cleaner usually helps in this case though it may not last long. If it's an open jack, i.e. you can see the contacts, a little cleaning with emery paper or very light sandpaper will clean them up. More common these days, jacks are enclosed in a plastic "box" making mechanical cleaning difficult (a needle file works.) Finally, if the jack is the type which switches of speakers to power a headphone (unlikely in the OP's case), there is an additional "spring" contact which reconnects the speaker circuit when the plug is removed. These tend to weaken with use but sometimes can be bent back to establish a proper connection.
Glad to hear you got your speakers working, munidgtm!
thanks for adding in! nineball9 ! i do a know bit about this pre-amp and power-amp stuff as I'm an engineering undergrad myself so i can understand you're reply!
