*** Update. The systems functions fine with a different power supply. The motherboard seems to function fine. ***
This board is giving me a lot of headaches. First a component list.
-P67A-UD3
-2500K
-Seasonic S12D 750W
-ATI 4870 1GB
-GSkill Ripjaw DDR3 1333 8G
-Kingston 64G ssd
WALL OF TEXT ALLERT
Alright, the ssd and the 4870 were old and swapped over from a different system. The system originally booted up just fine, i went right into the bios and bumped the voltage up 1 point and set a mild overclock. Just under 4GHz, the system booted up fine, however i missed the option to boot from a CD to load up windows 7 and the computer started to load from the old windows 7 installation. I did a hard shut down and tried to reboot. The computer would turn on for a split second and shut down.
I unplugged everything and cleared the CMOS, this caused it to boot and i got a corrupt BIOS message and it loaded the backup and then shut down. After this the computer would only start for a split second again. Clearing the CMOS once again finally got it to boot. When it finally did boot the bios was back at factory settings and that is where i have left it for now. I loaded up windows 7 and it installed fine.
However, everytime the computer is shut down it requires what i have dubbed the "clear CMOS" dance. This is unplugging power, shorting the bins, pressing the power button with the power supply not plugged in etc. The computer will do multiple split second power ups. Praying to the computer gods is required to get it to power up completely which is usually accompanied by a menu to select "default boot or last known successful settings".
Is this a dead board? Should i be RMAing? I noticed that there is a new bios out which i will try flashing after work to see if this fixes anything, however i also understand that the @bios program bundles with the motherboard doesn't work and requires a new version.
Any one else expierencing the same problem?
-P67A-UD3
-2500K
-Seasonic S12D 750W
-ATI 4870 1GB
-Kingston 64G ssd
WALL OF TEXT ALLERT
