P67A-GD55 wont post...
ribkage7
Anything special I should know that Im missing? All the fans turn on and it never beeps or goes past "LED 1" on the mobo. The LED stays lit, which the manual says "CPU Phase 1 power mode" and "Both of primary and second BIOS are failed"
Ive tried the stock hs/fan and the coolermaster hyper 212 plus. Ive used arctic silver and the coolmaster thermal paste.
I checked the pins under the cpu and they look fine, I do have a magnefying glass.
Ive got 5 120mm fans total all sucking/blowing in the correct directions. Going down to 4 after all is said and done because one is loud as hell.
Ive tried it without RAM and ram in every slot/combo of slots
Other components are
i5 2500k
Gigabyte nVidia geforce 560 ti (Im gonna sli eventually...few months)
Corsair tx750w psu
G.SKILL Ripjaws X Series 8GB (2 x 4GB) DDR3 1600
Western Digital Caviar Black 640GB 7200 RPM 64MB Cache SATA 6.0Gb/s
Cooler Master HAF 912 mid tower
I kinda dont know what else to do besides RMA it. I really dony like MSI and only got this board because nothing else was in stock.
If I cant fix this should I just grab a GA-P67A-UD4-B3 instead? http://www.newegg.com/Product/Produc...82E16813128478
Plz help! lol, I wanna RMA this sooner than later if I cant get it to post.
EDIT
Ive built tons of PCs and this is the first time Ive ever had an issue, luckily.
Oh, and I quit smoking yesterday (Im 30, its not as hard as it seems). So lets try to make this as low stress and redundant as possible.
Other than trying a basic out of case test with just the mb, cpu, 1 mem stick and gpu just in case you're shorting out somewhere I'd say RMA it.
man I feel your pain
I've said it before, and I'll say it again
I always keep around a really crappy basic vidcard and a stick of really crappy low speed RAM that boots at stock voltage and basic MS branded mouse and KB just for these type situations.
And of course unplug and disable in bios anything not related to simple booting, including modem
