P5W DH problems?
imported_AZSnake
Whenever i unplug my tower from the wall socket or it loses power besides shutting windows down it does not reboot unless i clear CMOS. Once CMOS is reset it will boot fine, and you can shut it down and it will post everytime. I pulled the entire build apart last night to reseat my HSF with AS5, and only hooked up the bare essentials. It posted right away and I thought it was remedied. Unfortunately, once i hooked up my SATA drive/DVR-R it went back into the same routine.
Do you think this is a mobo issue? I checked for everything that would short it out etc.. Once you get it to boot it works really well and I don't have problems. I am still in warranty and am trying to see if i should bring this board back or not.
As far as my temps go, I think I'm alright but I would've like to see mid 30C so I could start overclocking. My core temp is around 39-41C at stock (which I was trying to fix) but I believe that is due to the ambient temp in my room (arount 78F). I am see some of the low temps on here and sometimes wonder if I got a lemon. :p
System Specs
Intel C2D E6600 (week 25) stock
ASUS P5W DH Deluxe
Corsair XMS2 PC6400 (running at 400fsb)
eVGA 7900GT KO
Seagate 250gig SATA HD
Samsung DVD-R
Creative Audigy 2 ZS
Power/Cooling
Antec Sonata II tower (450w PSU provided)
Zalman CPNS9500 LED
Antec 80mm fan
Thanks for any advice you have to offer, keep posting cause this site has helped me out a lot!
phile
829
You're at very high FSB. Did you fully test that your machine is stable at 400? Do these boot issues happen at stock settings? At this point, I would guess that your overlock is not stable.
-phil
imported_AZSnake
That is correct, it does happen at stock settings also. I am running at a 2/3 ratio, and although the mem is high it seems to run great once I get it to post. I have never had a random reboot, so i'm not sure if my mem settings are the cause. I am a n00b however so who knows. my SPD timings are 5-5-5-18 and i have it set at ddr-800 at the moment.
So basically my machine runs great once it actually boots. It only requires a clear of CMOS if it is unplugged from the power strip. :( Otherwise you can shutdown, and restart with no issues.
Thanks again for all the help Phile.
phile
829
That is truly a strange problem. I wish I could offer more in the way of suggestions, but I'm quite stumped. Perhaps, I'll think of something later.
-phil
imported_AZSnake
Originally posted by: Skott
Out of curiosity which mobo BIOS version are you using?
I am currently up to date and using 1305. My pc had boot problems prior to flashing it, I was hoping the latest version would've fixed it. I was originally using 0801.
phile
829
It might be worth it to try a different power supply. At this point, you need to eliminate your components, one at a time. Might as well begin with the PSU.
-phil
Gary Key
866
Set your memory to a 1:1 ratio, it appears from all indications you are at the ragged edge of your memory capability provided you have also increased the CPU/MCH/DIMM voltages slightly.
imported_AZSnake
-phil
Sounds good, guess I'll give that a try. I know my PSU isn't great because it can't handle upping the VCORE when i tried to overclock. I'll go back this afternoon and set my ram to a 1:1 ratio. Thanks for all the help, I know many here appreciate it.
