I have a problem when trying to set the FSB Termination Voltage on a Asus P5Q SE Plus motherboard. Whenever I try to key in a value or press the + or - key to step through the available settings, the BIOS stops responding to key presses. Pressing num lock or caps lock will make the LEDs light up/dim so I know the machine hasn't hard locked. I can set the voltages or any other setting in BIOS without any problems. I have applied the newest BIOS rom on this board for the past week or so and have not encountered any other problems. I have to press reset or power cycle the box since I can't exit out of BIOS with the Esc key. I've tried loading default values then attempting to set the voltage again, but the same problem occurs.
Anyone else seen this behavior or something similar?
