- Apr 1, 2008
- 17
- 0
- 0
So got a P5Q Pro here, noticed that with LLC on, my voltage in CPU-Z actually goes UP when I put a load on it with ORTHOS.
The CPU is an E7200 and I have my voltage set to 1.400 in the BIOS, and the idle voltage in CPU-Z is 1.375. But as soon as I put a load on it, the voltage goes UP to around 1.384v.
This seems somewhat counterintuitive to me considering vDROOP is supposed to DROP voltage?
Can someone explain what's happening.
Just for information purposes I do have Loadline Calibration enabled. CPU doesn't seem to be stable though without LLC enabled.
FSB: 400
Multi: 9.5
RAM is 4GHz of OCZ Platinum XTC Rev. 2 (4x1GB sticks) at 1.9v in the BIOS.
While I know CPU-Z voltage readings aren't 100% accurate, surely the voltage shouldn't go UP?
With my old board (P35-S3G) the voltage had always gone down when I applied a load.
FSB: 400
Multi: 9.5
