P5B Deluxe Wifi-AP and WD Raptor harddisc problem
Tlaloc
Hi!
My motherboard and all of the other components arrived yesterday and I installed it.
When I booted the computer, both of my WD Raptor discs would`t be found at all
I have:
P5B Deluxe Wifi-AP Motherboard
Intel Core 2 Duo E6700 2,67gHz, 1066FSB Prossessor
4x 1024 NvidiaSLI XTC DDR2 PC6400 RAM
Asus GeForce 8800GTS 640MB
Harddiscs:
WD Caviar S-ATA 250gb
WD Caviar S-ATA 500gb
WD Raptor S-ATA 36gb
WD Raptor S-ATA 150gb
Both of the Caviar discs is found easily.
And everything else works good.
Since I was planning to install Vista on one of the Raptor discs, you probably understand my frustration.
Then I installed Vista on the 500GB disc, and I started to install the software that i got with the motherboard.
Raid controller got installed, but still no Raptor discs
The raptor discs won`t appear in the bios and vista
Any good advice to install raptor discs on this motherboard and Windows Vista?
- Tlaloc
