1. What YOUR PC will be used for. That means what types of tasks you'll be performing. fallout las vegas, diablo 3, etc
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread $750
3. What country YOU will be buying YOUR parts from. US
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc. I5
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are. Monitor
6. IF YOU have searched and/or read similar threads.
7. IF YOU plan on overclocking or run the system at default speeds.
8. What resolution YOU plan on gaming with. best possible with budget
9. WHEN do you plan to build it? next week
10. Don't ask for a build configuration critique or rating if you are thin skinned
