Considering that Intel decided not to validate the i850E chipset for use with PC1066 memory, we had our doubts about the P4T533?s headroom. Nevertheless, we were able to increment the front side bus until resting at 150MHz as the most stable overclocked setting. Of course this resulted in an equivalent 600MHz system bus and PC1200 memory speeds. Our 2.4GHz Pentium 4 rested comfortably at 2.7GHz, though we suspect the memory modules limited our overclocking attempts, since extra CPU voltage had no effect on system stability above the 150MHz bus setting.
Link here.
Mmmmmm PC-1200 speeds... Mmmmmm....
