Just got a Asus P4s533 (refurbished from new egg), clean installed winxp, and try to OC my 1.6a to 2.4. I used the +0.2 voltage and set the voltage at 1.6V in bios. Consequently, my bios show a 1.71-1.74 voltage. Using asus probe, I get a 1.7-1.71v reading when windows loaded. However, once I do my prime95 test, the voltage drops to 1.65-1.67v. I heard from other threads that this is normal, however, I don't feel comfortable with this kind of voltage drop. Is it my power supply? I am currently using a sparkle 300w PS. Should I get a stronger PS (thinking about a Antec true power 430), would it fix the problem? I am a little worried that this voltage drop will make my system unstable at times. Should I up the voltage higher to give more room for the voltage to drop and still be able to run the CPU at 2.4ghz.
In addition, I noticed that the 3:4 is not available for anything more than 132FSB, I heard there are some hack for the P4B series to make this available, is there a trick to enable this for the P4s533. I just received my Corsaid DDR400 CL2.5 stick, I would like to utilize ddr400 if possible or else I feel like I just wasted my money on the ram. please help.
