P4S333 and Win2k. HELP!!
JoeBob
84
Just got the P4S333 and a 1.6a. I got everything together and it posts. I can start the Win2k install, but when it gets through the initial file set-up and the "Setup in starting Windows 2000" message appears, the system hangs. There is nothing installed but the CPU, floppy, cdrw, and video card. I have set the boot drive to be the cdrw for install. The only mistake I know I made is that I did not connect the 4 pin power plu for the P4 the first few posts. I did when I noticed, but no difference. That wouldn't have damaged anything would it?
One other thing, the HD LED comes on only briefly during post. It does not light up again before it hangs.
I will admit that I was tired last night so I haven't tried as much as I normally would before posting, but I thought some of you may have some ideas for me to try when I get home. Thanks for whatever ideas you may have.
P4S333
128 M Kingston PC2100
1.6a
Seagate Barracuda IV 40 gig
Liteon cdrw
Gainward GF3ti200
Antec 350W
AndyHui
Administrator Emeritus<br>Elite Member<br>AT FAQ M
17
<< CPU, floppy, cdrw, and video card >>
Hard drive? And RAM?
JoeBob
84
Sorry. I asumed that those were a given. Types are listed in the sig. The HD is on a seperate chanel and is the master. Memory is in the first slot.
kazanjig
46
I had a similar problem setting up my P4S333 and 1.6a. If the harddrive is the only thing on the IDE controller you need to have it set to "Single" not "Master".
Check your drive's manual.
kazanjig
