P4S33 and USB troubles...
SmoothSL
Running a 1.6a at 2320 (145x16) at 1.6volts. I get temps of no more than 53C using the ASUS monitoring util.. Problem is when I run and play Medal Of Honor for a while, when I exit, I get an error stating my HP P1000 printer is not connected to the system.. I'm assuming this happened at some point when I was playing and not when I exit because it kicked me out of the game at one point due to it prompting me it was disconnected.. Now, the best I can tell is that the USB ports are dead.. I can plug in an Optical Mouse to the USB port and get no activity, the light should come on.. The only way to regain my USB is to do a reboot, even a warm boot is fine.. I also have to cycle the power on the printer, meaning I have to unplug it from the wall to even get it to come on. I'm assuming it is something with heat.. I don't believe 53C is much to worry about, but who knows how accurate that is. I have since placed everything at the norm, 100 FSB and 1.5v.. So far so good.. Do you think the Northbridge could be getting too hot?? Not sure what controls the USB ports.. But something is giving up the ghost.. Thanks for any help...
