I have an antec SX1000II Series case with the 2 USB ports on the front of the case, I have the wires inside.. looks like ~8 connectors per wire. I looked in the case manual it says the front is a USB/1394 Port Cover. I checked the MB manual to see where to hook it up.
So I look into the MB manual and get 2 spots i'm unsure of...
the first says:
USB headers (10-1 pin USB_56, USB_78)
**NEVER connect a 1394 cable to the USB_56 or USB_78 connections. Doing so will damage the motherboard!
next is:
IEEE 1394 connectors (10-1 pin IEEE1394_2(orange))
**NEVER connect a USB cable to any of the IEEE 1394 (orange) connectors. Doing so will damage the motherboard!
due to the nice little warnings in the manul I wanted to make sure what to put where before I actually did anything.
so I have 2 wires.....do I have to follow the 1394 cable from the front put those in the (orange) pins and the other to USB_58 or USB_78???
or both to the USB_58 and USB_78 pins. cables don't seem labeled in a way I understand which would be for the 1394 pins (if either). and one that goes to the USB..do I hook it up to USB_58 or USB_78 or both?
yes i'm an extreme n00b at this front USB port connection stuff...
the first says:
next is:
