p4p-800-e delux>>> sata problem
stimpy
ello,
i got a new hdd yesterday and got some problems
its a maxtor diamond 10 250 gb 16mb cache sata drive
ok this is what i did:
i installed the hdd and conected all the cable's correctly (duh)(on the sata plug on the motherboard (sata1)
tthen i powered p the pc and run windows xp setup
pressed f6 to install the sata drivers and setup recogniced the hdd nicely
made 3 partitions
on the first partition i tryed to install windows xp
the first attempt to install it failed becouse it hung during windows xp installation
2nt time the same thing happened so i tryed it 1 more time..and it installed windows completely at 3th attempt
now in windows xp i get blue error screens when i try to install programs like service pack 2 for xp
i writed down 2 errors:
_______________________
kernel_data_inpage_error
stop: 0x0000007a
stop: 0x000000ce
allso after the error i have to reset the pc...but after pushing the reset button.....the hdd led flashes 5 times slowly, and the hdd dissapeart in the bios.
shutting the pc down by pressing the powerbutton and turn the power on again makes the hdd appear back in the bios..and windows loads again.
i tryed to replace the data cable with a new 1 but no effect
bios is updated
system info:
pentium 4 3.0 ghz
1 gb ddr ram
motherboard: asus p4p-800-e delux
_______________________________
can anybody help me out? im out of idea's
thanks
