P4C800E-Deluxe; Problems with IDE bootup
mbatte
4
I upgraded my CPU, Motherboard and Ram.
Got a P4 2.4C GHz CPU, the ASUS P4C800E-Deluxe board and 2 PC3200/DDR400 512M memory sticks (total 1G).
I have 1 floppy, 2 CDroms and 1 HDD (Quantum Fireball - 30M, 7200).
In the BIOS set up, it recognizes my HDD as the Primary Master and the CDRoms as the Secondary Master & Slave. With the HDD connected to the blue port (primary) and the CDroms connected to the black port (secondary).
The problem occurs when I boot up. When it gets to the part where it is loading up the FastTrack portion and is scanning the IDE drives, I get the following error:
"No device is attached to the FastTrack controller, The BIOS is not installed".
Then it says
"Reboot & select a proper boot device or insert boot media.."
It seems that it does not recognize my HDD as a bootable device. The BIOS settings were all at default settings. I also changed the "Onboard IDE operate mode" to "Compatible" so that I could set it to P-ATA Ports only but that did not work either. But since I have Windows XP, it should stay at Enhanced which does not work.
I went in to the BIOS and Disabled the "Onboard Promise Controller" as I do not need RAID.
I no longer get the 1st error about the device attached to the FastTrack controller but I still get the Reboot and Select a Boot Device or insert Boot Media...
I guess it doesn't like my HD. Not sure where to go from here.
Since I do not have S-ATA or RAID, I'm unfamiliar with the settings that I require to get my Hardrive working. I would imagine that the HDD I have is considered to be a P-ATA (UltraDMA) - but I do not know the difference. The HDD I have is about 2 yrs old and I think the S-ATA's are newer - so I do not have a S-ATA.
Could someone please let me know what settings are required for me to use so that I can boot up the system.
Regards,
Matthew Batterton
mbatte
4
Boot sequence:
1 - floppy
2 - HDD
3 - CD
Tried using the HDD 1st, still no difference.
boyRacer
18,569
Have you flashed to the latest bios? I have no experience with that board so bear with my shots in the dark. Perhaps people at the asusboards.com can you help if for some reason you can't find your answer here. :)
mbatte
4
Can't even flash the BIOS as it won't even recognize a disk in the drive. It doesn't read it at all.
Seems that it just doesn't follow the boot sequence and jumps to that error message.
Thanks for the other link - I'll try that one too :)
