P4C800Deluxe-E or IC7-G Max2 Advanced?
Jincuteguy
380
which board has more features and overclocking abilities???
Asus P4C800 Deluxe-E or
Abit IC7-G Max2 Advanced
Wurrmm
428
Both are top notch, but the Abit is better for OCing and IMO more stable.
klc314
50
That's a matter of opinion, both are good boards, I happen to feel the ASUS is more likely to be more stable. Overclocking options are excellent on both boards, do some research. ASUS has a history of reliability and stability right next to Intel. Now, they have a lot of overclocking options as well.
Fallengod
5,908
19
Asus is probably more stable, ive heard abits having far more problems than asus have lately also so...
Thor86
7,886
7
Really depends on if/how much you plan to overclock your P4. If more than 250+fsb, then I would suggest the Abit over the Asus.
The main thing to consider is when ocing a cpu is:
Asus = 3 phase power/overvolting+more vcore swings from idle to full load on the cpu (usually about 0.06).
Abit = 4 phase power/undervolting+less vcore swings from idle to full load on the cpu (usually about 0.03).
