lots of questions to be made about this config i've been "playing" this afternoon.
First of all: is there any way of unlocking p4 multiplier?
- what's the meaning of ddr settings and what is expectable "standard"oc-ability of this config.?
- would an adequate cooling do much for this intention or would it be just the less important factor?
- where are the reasonable limits of 2.4b
- would rimm memory be more adequate thah ddr for this chip or is it just impossible (appart from the mobo of course)
- what are the right settings for agp/pci (voltage, freq...) and what are acceptable values?
- what about strength and other parameters in order to better oc?
-whatever else you think adequate.
thanks alot.
not to forget MAM, what's mam?
thanks alot.
