P4B266 shows no temp with MBM or Sisoft and more.
Racer7201
338
I have the above m/b with a 1.7P4 and MBM or SiSoft doesn't show the cpu temp or m/b temp. ASUS probe showed the temps but they never changed, cpu was 40c no matter what. The bios showed 40c all the time also until I flashed to the latest bios, 1007ddr01. Now the bios shows the correct cpu temp, but still no readings through any of the programs.
I'm about ready to take this board back and exchange it. I still haven't figured out why the screen comes back garbled after the monitor goes to standby. I have to use the reset switch. System standby and hdd power down are set to never, just the monitor to off. I've swapped video cards, monitors, ps, ram, used default settings in the bios. The only time I haven't been able to get it to screw up is with the Standard PCI VGA driver loaded.
JF
Sys: Win98SE, P4B266-PA, P41.7g, 256m Crucial pc2100, IBM 40g Deskstar, Matrox G400 or Radeon VE, Magview or Packard Bell monitor, Antec 300w p/s, PCI128 soundcard, Trendnet nic.
RPB
335
i'm using a p4266-c and sandra dosn't show the temp at all but asus probe ver v2.16.02 shows temp,rpm and volts ok.
older ver showed 40c like yours.
