I have the P4B266 with on board audio and USB 2.0, a P4 1.8A Northwood, and 512mb PC2100 Crucial. I cannot get it to do 2.4, I think, due to some of the bios settings. When I set the FSB in the Bios to 133, memory at 1:1, it will not boot, no matter what I set the voltage too. This also happens when I have the Option set to Normal, Turbo 1 or Turbo 2. When I use the dip switches to set the FSB at 133, it boots right up and makes it to the start of Win XP loading, then freezes up. I think I would be fine if I could up the voltage when using the dip switches. I have it set right now at FSB 125 via the dip switches and it is running perfect at default voltage. I upped the voltage to the memory to 2.7v but that has not made any difference. Any idea why it won't work doing the settings in the bios?
