Hi all !
Well, am about to build my second 1.6A system for my brother-in-law. He has all the parts *except* for the motherboard - he uses DDR & yes, he too wants to overclock as far as he can....... He is **VERY** stubborn and only wants to use an Asus board - so I need to choose between the P4B- 266 or the P4B 533. Where we live, the P4B-266 will save him the equivalent of around $60US.
Now......I know the P4B 266 very well because that is **my** rig which I recently wire-modded to 1.7V to fix the cold / warm booting problems - thanks to all of you here for that - you were all a great help !!!!!
Here's my problem:-
=> he is VERY reluctant for me to in may way wire-mod his motherboard - which as I explained to him, would be **quite likely** if we got the P4B 266 [even though I have already done mine] ........... so ......... I need to know:-
Q => Are there any "issues" or "known" problems with the P4B-533 board & using it as a basis to O/C a 1.6A ?
Q => Has anybody here had to wire-mod their P4B 533 setup to get full voltage on boot-up ?
Q => Did the wire modding work %100 fine on your P4B 533 ?
After searching some older posts, I read that some people have said that the P4B 533 does NOT need to be wire modded even when o/clocking at relatively higher voltages like 1.70 <-> 1.75V -> so.....
Q => Does anybody here know if it is actually factually true that the P4B 533 does **NOT** need to be wire-modded to get full-cpu voltage at boot-up ? ie: does the P4B 533 apply the bios selected higher CPU voltage at boot up, or does it too boot up at 1.5V and then go to 1.7V like my P4B266 ?
Thanks to all in advance for your opinions / help.
Tillo
Here's my problem:-
Tillo
