- Mar 29, 2008
- 1,722
- 29
- 91
My Pentium 4 (Prescott) is running at 75C (167F). Is this temp too high?
I could invest in a better CPU cooler , if advised that is, since the stock Intel cooler is 5 years old now. The only one available where I stay is the Thermalright XP-90 CPU Cooler:
http://www.primeabgb.com/index...m_virtuemart&Itemid=53
Will it fit with the Socket 478mPGA? Also, should I invest in a better case to keep the airflow inside the case better? I'm currently using a CM Centurion 534 Plus case.
The P4 system specs are:
Intel Pentium 4 @ 2.4Ghz
Intel D865GBF Mobo
512MB DDR RAM
Sparkle 7300GT (512MB - AGP)
40GB Samsung
80GB Seagate Barracuda
CM Centurion 534 Plus Case
It would be awesome if someone could shed some light on this and clear my doubts.
TIA
Intel D865GBF Mobo
512MB DDR RAM
40GB Samsung
TIA
