p4 power connector...atx12v???
Duvie
16,215
I have a sparkle 350 watt ps...
That being said it says it is p4 ready but it appears I am missing the square 4 pin connection that I need to power the cpu....
Is there an adapter for this??
Does it generally connect to a 12v plug that is commonly used for drives???
Need help fast as I am about to order my p4 northwood and need tomake sure my power supply does not need an upgrade as well...
mechBgon
Oct 31, 1999
30,699
I think your signature needs an upgrade if you're ordering a P4 :D
I bought an Inwin V500 case which came with the P4 square 4-pin adapter plug. It plugs into a hard-drive-style 4-pin connector. If you want it, drop me a PM and you can have it for shipping costs. I'm in Spokane so it should make it by Monday via First Class mail.
