I am totally new to overclocking and just started to experiment with my 2.26GHz P4 yesterday. I?m using an Asus P4S533 with 512MB of Corsair XMS PC2700 memory. Right now I have my P4 set at 2.55GHz/150FSB with the voltage set around 1.5. I am using the default cooler and my idle temp is 40C. How far do you think I should be able to overclock my P4 using the default cooler and without stressing my CPU too much? My mobo won?t let me set the FSB beyond 166. Is that normal for the P4S533? I tried setting the FSB to 166 just a few minutes ago and the computer crashed, so I set it back to 150. Would I need heavy cooling or really high voltages to run at 166FSB? Also, the field where I change my FSB settings in the BIOS is labeled as CPU/PCI Frequency. What is the PCI frequency, and does it need to be locked at 33 or something? I also don?t understand most of the memory setting fields in the BIOS. In my BIOS, there are fields for: SDRAM CAS latency, SDRAM RAS to CAS delay, SDRAM RAS precharge time, SDRAM active time, and SDRAM command lead-off time. What do those fields mean and what should I set them at for my Corsair XMS PC2700? Should the memory settings be low when overclocking? Lastly, what is the CPU/memory frequency ratio and what values should I use for it? Sorry to ask such newbie questions, but I would greatly appreciate any help or advice.
