I've got a P4 2.2 setup. I'm basically lost as to what the problem is here, so hopefully someone here could help.
I've got everything installed, seated correctly, cables hooked up etc. However, when the machine powers up there's no picture. And the system doesn't beep at all as if there was a problem or the boot up was ok. The video card does work, as I tested it but no luck.
Any ideas as to what the problem could be? everything is getting power, mobo seems to be running, but I just can't get a picture or even a beep.
