P4 B0's seem to run cooler than C1's
John
Moderator Emeritus<br>Elite Member
4
When I had my Epox i845D mobo in this rig, I noticed that the C1 stepping cpu's were running roughly 6+C hotter than a B0 stepping cpu @ 1.525v. Now that I have an E7205 mobo, I am seeing the same results. Has anone else noticed this?
THUGSROOK
11,847
ill LYK in a few days! ;) :D
i did read something somewhere that any c1 cpu with HT disabled runs 5*C hotter :Q
Duvie
16,215
Wonder why disabled???? so pretty mcuh all c1s from 1.8 to 2.8ghz then would fall under this category???
oldfart
10,207
Ok, I'll bite. What are you getting?
Duvie
16,215
He is getting a c1 2.0a ghz oem chip!!!! He sure loves them A's.......1.6 to 1.8 to 2.0...I don't expect him to get another a again after this!!!;) Vegas should carry odds on Thugs buying habits...
John
4
I think he mentioned a 2.0 ;)
Intel has a price drop on Monday for 2.4 and above.
THUGSROOK
11,847
Originally posted by: Jgtdragon
Well, I do see my C1 runs hotter under full load. Same temps on idle.
could you run some HT on/off temp tests for us?
p l e a s e ? :D
Jgtdragon
3,816
19
Does it matter that my 1.8a doesn't support HTT? Running CPUburn now with HTT enable in bios.
Jgtdragon
3,816
19
Well, if you can help me find the hack to unlock this HTT with all P4 then I can test it. ;)
THUGSROOK
11,847
so far there is no hack.
even intel themselves claimed HT is enabled/disbaled during the manufacturing process and cant be changed.
not sure how true that is tho ;)
DAPUNISHER
32,094
32,636
p l e a s e ? :D
Here's an article that does just that
Link
John
4
Excellent article. It looks like 70ish is the temp to shy away from in order to avoid clock throttling.
I am trying to find a way to disable it in the AX4R+ bios, but I do not see an option.
