P4 3.4E - minimum power supply?
FishTankX
2,738
I think any qualityu powersupply with enough poweroutput could run a 3.4E. I'd be willing to guess 300-350.
SilentZero
5,158
If your going to invest in an expensive CPU such as the 3.4E, you might was well get a good high output PSU (460w and up).
Nebor
29,582
12
Originally posted by: OverVolt
why do you want a prescott? do you want your PC to double as a frying pan?
That's not what he asked. Let him buy what he wants. Tell him what kind of power supply to get.
Regs
16,665
21
It's like a 16 year old asking to get pregnant, but ok. The 3.4E prescott can draw over 103W's. So you would want the best PSU you can find. A 480watt plus if you plan on running it with a high end video card. A 380 or a 430 watt to be safe if you plan to keep you current video card.
Bovinicus
3,145
It depends highly on the rest of the hardware in the system. I wouldn't go with less than a 350W quality (Enermax, Antec, Thermaltake, Enlight, Sparkle, etc...) PSU, but once again, it could be more depending on the other hardware in the system.
Cerb
17,484
33
86
Wattage or price?
Price: ~$30 300w Fortron, Enlight, Antec.
Wattage: ~200w Shuttle-branded SFF PSU.
Best get a Antec, Enhance, Enlight, Fortron, Enermax, etc. 350w or so.
Nebor
29,582
12
He has a much better chance of hitting 4ghz+ w/ a prescott than a northwood.
Regs
16,665
21
Allieds are under rated I think. I ran a 380 watt Allied PSU with a 9800 with an overclocked 2500 Barton, and it was rock hard stable. But if you plan to overclock a P4 3.4E then I wouldnt want anything less then a Antec 480watt.
jswjimmy
892
a good 350 could do it if you have 1hd, 1dvd-rw, 1pci-card. i would get at least a true 400 or 450. just so you can add on later.
Edit: its a prescot,if not overclocking a 450watt, if overclocking 475watt or better. the dam cpu by it self uses 120watts.
