Trigger Aurelius
My Rig
MSI 865PE NEO2 PLS
P4 2.8C w/XP 90
4x512 DDR400 Corsair Value
BFG 6800GT
Antec SmartPower 400
Well, I'm trying to get a little more life out of this girl before I start over and go PCI-E. I have an AC NV 5 for the gfx card on the way, and will OC past Ultra speeds when I get that in -- I'm pretty good with the vid cards.
I'm a noob at CPU oc'ing, but I've done some reading and I think I understand the basics. Right now, I'm running at 210 FSB so 2.94 Ghz at 1:1. Prime95 says she's okay as well as MemTest. Stock voltages. Idle in the low 20's and load in the mid 30's.
From what I've gathered, my RAM will be my limiting factor as it's Value line and I'm running 4 dimms. I've read that I can run a memory divider to push the CPU further.
My Question -- Is the benefit from a higher clock speed greater than the hit taken from running a mem divider? I'm a gamer who currently plays a lot of BF2, thus the 2 gig's of memory. Or do I just push as far as I can go at 1:1?
Thanks in advance for any help!
MSI 865PE NEO2 PLS
P4 2.8C w/XP 90
BFG 6800GT
