P4 2.80C 800Mhz showing Mem Freq of 400Mhz during POST
lavagirl669
3,325
During POST I'm showing a CPU Mem Frequency of 400Mhz
for a P4 2.80C 800Mhz HT.
Is this a correct reading?
If it isn't how can I change it?
thanks
Lava
dennisjai215
Banned
Apr 16, 2004
1,261
from what i know is ur chip fsb = 800mhz & ur ram is DDR400
200 = 400 = 800 which is 200=800..
ur bios is 200xmultiplier? running with DDR400 PC3200...?
if this is true uh i think it is correct that it shows 400mhz mem
Sunner
Yep, it's correct, though technically maybe it should say "200 MHz DDR", but never mind that :)
RS3RS
Banned
May 3, 2004
243
It's correct. The 2.8C has an 800mhZ quad-pumped FSB, which is 200 mhZ actual FSB. The memory is running at 400 mhZ DDR (DOUBLE data rate), which is 200 mhZ actual.
200 mhZ on FSB, 200 mhZ on memory = 1:1 ratio
