Hi, just thought I'd share my early overclocking experiences so far. Specs are:
Asus P4P800-UAY (non deluxe) running 1007 final BIOS
P4 "C" 2.6GHz CPU
Thermalright SLK-900U Heatsink with Panaflo L1A 92mm fan (27db 43cfm)
512meg Corsair TwinX PC3200LL RAM (2 x 256)
WD Raptor 10,000rpm Serial ATA 36.7gig drive
Maxtor Diamondmax 7200rpm ATA133 40gig drive
Asus V7700 Deluxe Geforce 2 GTS 32meg (haha I know)
Antec Sonata with standard 120mm Antec exhaust (have two Panaflo L1A's waiting to go in but installing them is a bitch in this case)
I've been running it at stock while I installed things and made sure Windows was stable (all is well except I accidently installed the stupid Q818529 IE patch and now have trouble using IE and for some reason it's not on the uninstall list). Just tonight I bumped it up to 225 FSB (2925MHz) and putted around for a while without any problems. Now running at 250 FSB 320 RAM (1000MHz FSB and 400MHz DDR) for 3250MHz with HT and MAM on. Stock voltage, RAM at 2.65v running 2-3-3-6. Haven't had time to stress test but I played an hour of games (DOD, Quake3) without any issues. Asusprobe reports CPU at 36 under load, 27 idle - MB at 30 idle 34 load. These temps don't seem possible, but both the BIOS and Asusprobe report them the same. When I try to uses MBM5 it thinks the CPU is running at 85-90 (it does this no matter what, even right after a boot at everything stock, no idea why).
I'll update this after. Just thought I'd post about how well the 2.6 seems to do, and this case only has one 120mm exhaust fan blowing at ~1600 RPM and a single 80mm in the PSU also doing around 1700rpm, pretty quiet
P4 "C" 2.6GHz CPU
