- Jan 28, 2003
- 71
- 0
- 0
I want to start by thanking everyone for their help getting my system going.......especially duvie for answering my noob questions about OC'ing. Ok, I OC'ed to 2.61GHZ (1.575Vcore) and have questions about temperature before I go any higher. At this speed my CPU temp is 38C idle / 46C loaded. I'm using a Vantech Aeroflow HSF with copper core and 5400 rpm fan. My question is, what is considered too high of a temperature for the 2.4GHz P4? I looked on the intel website and found some information but not sure if what I found is what I'm looking for. I was looking at the datasheet for the 2.4 and the only mention of temperature is Tcase. The maximum Tcase listed for the P4 is 70C. But, that seems way too high for an operating temperature!!!!
Another question:
For those of you the have this mobo. The CPU and System temp seem to be mixed up in the BIOS. My CPU temp is always lower than my system temp. Has anyone contacted Albatron about this? I assume the temps are backwards because CPU temp is almost always higher than system temp.
Yet Another Question from the noob:
How do I update the BIOS? checked Albatron website and instructions are weak. It says I need to know the model number and revision number of the mobo and need to have a blank boot floppy. What's the revision number? And if the floppy is blank how can it be a boot floppy? Am I confused or something.
wow, that's alot of noobish nonsense for you all to ponder. Thank you for your help
