P4 2.4/400 running @3160? IS THIS RIGHT?
WigglePuppy
87
using a new P4c800 with settings in bios for auto overclock @30%, temps now CPU 33C using ASUS PCPROBE....oh well Im happy, gunna run some test later...
Apr 17, 2003
37,622
Originally posted by: WigglePuppy
Yup, that's the only thing I had changed, and wondering if I can push this with manual settings...
i sure you have a bit more room to go but my question is why would it show as 3160 when 30% OC is 3120???
Slammy1
2,112
Be careful. The retail fan throttles, so it's not the idle temperature that should concern you. A 30% overclock corresponds to a 260Mhz FSB. Depending on your memory, you should run that on a 4:5 (320MHz Memory frequency) or a 3:2 (266 mem freq). Timings are dependent on your memory quality and which divider, something like 2-3-2-6 for tight 2.5-4-4-7 for loose. I'd also turn off turbo mode (Performance Mode - Standard) and enable MAM.
dbwillis
Banned
Mar 19, 2001
2,307
2.4/400 is 24x100fsb right? so a 30% OC is only 133fsb...
Or did you mean 2.4/800, 12x200 would be 260fsb...
nealh
7,078
his board may be rounding slightly to give a different figure..My Abit IT-& MAx 2 revv 2 fsb of 166 is actually 166.6 so I get 3ghz or 3.01ghz
WigglePuppy
87
Ok, now ASUS porbe is reading 3144 on processor speed. Can I get some suggestions to change settings manually. I am using crucial 2700 DDR 1.5GB for ram, P4 2.4/400, not 533 or 800 with Coolermaster IHC-H71 and GForce4 Ti 4200 64MB AGPx8. Thanks, last time I overclocked a chip was with a P2 300....oh boy, showing my age.....
Slammy1
2,112
Run CPU-Z to get an idea of memory timing and which divider you're running, otherwise what I have listed above should work. I thought you were running the P4P800, but the BIOS settings should be close. For stability testing, run Prime95 and some multimedia (like 3DMark03, which I don't usually run because I can't watch temps, or maybe watch a DVD while playing WinAmp with visuals and playing a Divx file in WMP)). Also check out the P4C800 thread in the Motherboard section, it will give you some hints.
The P4P800 does some interesting rounding. In fact, I've seen it post different speeds at the same BIOS settings (a little added random number?).
Apr 17, 2003
37,622
thanx a lot, that was driven me crazy
WigglePuppy
87
Man this sux,.....temps now, CPU 32C/89F, MB 31C/87F its a GF4, so some where in the mix ther is a problem, could be the AGP bus, although ts an 8X AGP PNY...man talk about upseting...temps normal and pretty decent, compared to AMD where temps 50-60C with +1900...:confused:
OverVolt
14,278
89
That score scounds about right for a Ti4200 since it's not DX9 compatiblt right? Only the FX+R9500+ can score decent on 3DMarks despite CPU.
WigglePuppy
87
i do not have another system to compare it from so, make it difficult to do so,.....none the less, these are crappy readings....and I do have DX9.0a so, dunno if this makes a dfference.
Apr 17, 2003
37,622
you can compare it too others with similar setups on the futuremark site once you publish your results
