Thanks for the quick reply, but I don't believe that these are for the FC-PGA2 PIII Tualatins. It appears that they are for teh regular PIII's. Any other suggestions?
I have a tualatin P3-S... and all the heatsinks ive used for it are for Coppermine P3s... no problem. The only thing that probably won't fit are the those orb coolers and the articooler... if you still don't feel comfortable just take off the clip and bend it out a little to compensate for the small inscrease in height... but i wouldn't be worried... that heatspreader is there for a reason.
