An Asus CUSL2-C motherboard is a great choice, it has great overcolocking ability, if you need onboard audio get the cusl, they are both great choices!
I have been using asus boards for a few years now, and i havent had one crash yet, i traded them away for newer ones, i am sure the msi board would also do fine for you i have heard good things about it...
