P3 933 temps
It's otherwise stable, I have an old case with no options for case fans (though it does have lots of holes for ambient cooling on the front rear, and left side), I have a speeze falcon rock on it, and a fortron 350W 120mm psu. Case temps are 36C, HDD temp is 30C
I was wondering if anyone can report thier P3 temps to get an idea if I should upgrade my case for little more cooling or not. (I'm a perfectionist)
Another strange thing is that speedfan doesn't recognize the fan speeds on my particular motherboard.
p3 733, max temp is like 42 celciuson hot day under load for like 4 hours playing games, average its 39 celcius, case temp is 21, dunnoh about hdd butit would be around 25-27 i would guess by touch....
the processor has a ghey fan, the video card has a fan but no other movement of air thorugh the case, i keep it closed and stuff too, oh yeah the psu has one fan too...
got a P3 1ghz running full load most of the time (folding) and it rarely gets above 40c. and its on some kind fo stock thingy 😛
Originally posted by: MercenaryForHire
I'd ask your BIOS what it thinks the temps are, those sound pretty off.
P3 733, running in a super-tiny case with minimal airflow, 45C load.
- M4H
my bios doesn't have a health monitor section, and I'm leaning on speedfan not being accurate too, I just felt the air coming from the back of my psu, and it's only 1 maybe 2 degrees warmer than ambiant. my 2500+ box is over clocked to 2.1Ghz and runs 50C 24/7 and the heat from the psu and rear fans are pretty warm in comparison. I guess as long as it's stable I'll leave it alone.
