I'm trying to use a Pentium 3 1GHz/133MHz on an ASUS P2B using a noname slocket adapter ("370SP rev 2.0"). The mobo revision is 1.10 which doesn't officially support this CPU, but its voltage controller should in fact be capable of going as low as 1.3V (HIP6019BCB).
Should there be a problem running this CPU at 100MHz to get 750MHz?
So far I was unsuccessful. The computer turns on as soon as I switch the PSU's hard switch on (normally it turns on only after pressing the ATX soft power button), there are no beeps of any kind, and it does nothing.
I tried the slocket on "Auto VCore", auto FSB, 100MHz FSB, and forced voltage. Its documentation lists jumper positions for as low as 1.8V, which I tried. Despite it not being listed in the docs, I also tried 1.7V (the 5 jumpers correspond directly to Intel's VID). I even tried setting the mobo's CPU multiplier to 7.5.
I'm not 100% sure the slocket and CPU are okay, but as far as I remember they both worked the last time I used them. I did, though, have to struggle while removing the heatsink off of the slocket when to take out the previous CPU that was in there. There's also a chance the heatsink/CPU contact isn't perfect (if it matters anyway).
Any ideas or thoughts?
