p182 Help and thermalright ifx-14
What motherboard is it going on? What fans are you planning on using and in what orientation?
and if for no other reason, could you edit your initial post to reflect the proper company. The IFX-14 is made by Thermalright not Thermaltake. They are completely seperate corporate entities making coolers that are fundamentally quite different.
Originally posted by: starchbrother1
i have a 780i evga board.
Thank you for the edit, I'm a bit OCD. AFAIK it will fit but, not with fans mounted above or behind the heatsink though the case fans should fit and a fan mounted to the front of center of the heatsink should fit if 120mm; the IFX-10 rear motherboard heatsink will not fit. All in all it could be a good silent solution for you, so long as it does fit with that exact board, I would say check out the reviews out, specifically, madshrimps is pretty good, as it lists the full heatsink sizings and you should be able to extrapolate for sure if it's going to fit.
