P180 Lower chamber fan
bgc99
472
What would the recommendation be for the lower chamber fan, run it on low speed or set it on High and then connect to the thermostatically controlled fan power connectors on my TPII-550 power supply?
BGC
JBDan
2,333
Low speed 24/7. ;) Unless you have 3 scsi drives in the lower HD cage.
AznAnarchy99
14,695
117
i have 2 hard drives down there, one IDE and one SATA. They run amazingly hot with low speed for me.. i keep it on high now. Low 40s temp for hard drives compared to the 50 idle i was gettin
MDE
13,199
Low should be fine. My Raptors are warm to the touch with mine on low.
