P180 front audio help!
lOnGjOhN
197
How do i go about connecting this to my audigy2zs?
there are ALOT of pins and i don't know where goes where because i lost my manual.
or do they fit somewhere on the motherboard?
tiap
572
Which manual did you loose?
P180 is available for download, so should the one for the sound card.
Just match the pinouts.
Deinonych
633
Originally posted by: The Boston Dangler
You don't. This has been discussed elsewhere, but to summarize, you can't connect front panel anything to SB cards.
That's not necessarily true. If you have the patience and the soldering skills, you can create your own front-panel connector. Instructions here.
AmberClad
4,914
Find someone willing to sell their Dell case and strip the front panel --> mobo/Soundblaster audio connector cable?
