P180 + Corsair 520/620HX + Abit IP35 Pro- Does your 8-pin cable reach?
MichaelD
Next week I'll be installing the IP35 Pro in my P180. I have a Corsair 620HX PS. I'm concerned that the 8-pin power cable wont' reach.
Does anyone have this particular combo and did your 8-pin reach? Thanks!
Thanks, John. Will it reach even with an aftermarket heatsink (Freezer7)? I neglected to add that detail to my OP.
It will reach but only in front of the motherboard right? I know with my HX620 and P180 and Gigabyte DS3 I routed it behind the motherboard and it was a bit of a stretch so I got an extender for it.
I don't have the P180, but I do have a CM 690 & HX520. I had no problem routing my 8-pin cable behind the motherboard to hook up on my IP35-E.
