imported_browsing
I've got two p180 setups. The more pressing of the two is my main rig, which has the following specs:
P5W DH Deluxe
6600 @ stock (for the time being)
Big Typhoon
2 gb g.skill 800
4x 320gb seagate .10
150gb raptor 16mb
PC Power & Cooling Silencer 750
Sapphire x1900 xtx
I've got the raptor in the top hd rack, while the bottom rack is full of the 320gb drives. Currently I've got 4 fans in the case; the stock fans in their regular positions, save that I've turned the top fan into an intake, but I've added one of those tri-speed Antec fans in front of the top HD rack. My x1900 xtx is sitting at between 58-60 idle, though it doesn't raise too much up. Before I installed the Big Typhoon it was happily at 49-52 or so. I've also noticed a slight increase in temperature on my hard drives as well, maybe 1C or so. Is there a way to combat the hugeness of the Big Typhoon? What are the absolute best fans as far as quiet/airflow goes? I've heard the Yulane Yates (spelling) talked about quite a bit but I believe this is because of their price as well as their decent ability? Is there something more pricey that would really move some more air through my case without sounding like a turbine?
My wire management should be just fine, I took a few hours to really clean it up, especially the 5 sata cables. So I'm just curious as to why (while I've seen an improvement from my Zalman 9500, especially in keeping Orthos load temperatures under 50) everything else seems to be suffering at the mercy of my Big Typhoon.
P5W DH Deluxe
Big Typhoon
2 gb g.skill 800
150gb raptor 16mb
Sapphire x1900 xtx
