P180 and fan controller
JDawg1536
I just ordered a P180 and want to set up a fan controller. I am wondering if the fan on the rear of the case will be able to reach all the way up to the controller, since the case is so big....
Most fan controllers include at least a few fan extension cables. The Sunmbeam Rheobus is an exception, but extensions are usually available for < $1. each wherever you buy your fan controller.
.bh.
What kind of tails do the tri-cools in your P180 have, mine came with 4-pin molex tails on the fans and I don't think that will be compatible with most fan controllers.
Shoot Im not too sure, I just ordered it and havent received it yet. Anyone know?
Dont the fans have a controller built in? And if you still want a controller than you can get a molex to 3 pin adapter, some controllers include it in the package.
Just use these, you will probably need the extra length for the rear fans anyways.
