- Feb 29, 2000
- 544
- 0
- 0
Here is my situation I was planning on upgrading to either a p3 700 or a celeron 566 for overclocking. I read a review of the cubx on anandtech as well as got apex? that both said it was a great board for overclocking. So I decided on the celeron 566 since my current memory (256 megs 128 kingston value toshiba modules, 128 micron) is pc100 and i don't want to replace it with 133 to overclock the p3. So I ordered the celeron from buy.com (celeron is still backordered so i could cancel it) and I bought the cubx from mcglen.com. However right after getting the cubx from mcglen.com I start hearing about voltage problems with the celeron 2 (dirty weasle on this board had quite a bit to say about it
) Anyway to get to the point what should I do?
A. Is it a fixable problem that Asus could just release a bios update and fix it?
B. Cancel my Celeron and go with a P3 without much overclocking ability?
C. Send the board back at a restocking fee and get something else?
As you can see i'm baffled and would appreciate any help PLEASE!
