Ok, Here's the deal... My computer crashes frequently after serious use. I'm almost positive it's overheating; I've reformated, and taking the side off of my case fixed the problem tremendously.
I'm 99% sure that my video cards are overheating; my CPU fan is a Zalman 7700-CU = Insane cooling. Speedfan says my CPU is running in the low 30's, max, so I'm not worried. On the other hand, my video cards have temp reports all the way up to the 80/90's! There is a dead fan in my OCZ 600W PSU, but I doubt the PSU is overheating: It's out of my case completely with decent airflow.
I have no virus protection, but use spybot and have a good firewall; I just reformatted anyway.
Now... I would usually upgrade the fans on my cards, but that would void the lifetime BFG warranty. I would also put a small PCI slot fan in there, but they seem to be ineffective (Know of any REALLY good ones?) I can't just complain to BFG and say it's overheating, they'd at best just send me an identical one and that wouldn't solve any problems.
Suggestions?
Suggestions?
