- Apr 29, 2002
- 383
- 0
- 0
My computer crashes after a while in intense 3D games like UT and B&W. I'm pretty sure this is a heat problem from my video card. I have noticed others talking about geforce2 gts cards getting pretty hot. Doese anyone know if mx400's usually have this problem? The brand is Pine and I've noticed that it's the only brand that doesn't put a fan on the card. But when the computer locks up during gameplay, I can feel the HS on the card is barely warm, but the top of the card (opposite the MPU) is practically on fire. I'm guessing there's close to a 40 degree C difference between the two sides of the card. I'm currently getting a new case fan since I really needed one more anyway. I have also seen where some people attach an old cpu fan to the top of the card with double-sided tape and a couple of motherboard mounting brackets. Does anybody have any suggestions, comments, or rants?
I've also noticed the northbridge on my motherboard is just as hot during gameplay. If that's causing the problem, it may be a little harder to get to since the HS and fan for my SlotA Athlon partially eclipse the HS on the northbridge. (I think it is the northbridge, maybe the southbridge.)
My setup:
Athlon 500 (Slot A), 256MB RAM, MSI-6167 motherboard (with 2x AGP slot), Pine agp geforce2 mx400 with 64MB SDR RAM, 250W PS, and I don't think the rest matters.
I haven't done any overclocking or anything, so these parts are as is.
Tim
My setup:
Tim
