- Jun 27, 2010
- 3
- 0
- 61
hi friends pl help me to 'overcome' the overheat problems.
my config -
Asus M3N78-EM motherboard
AMD6400 X2 (3.2. GHZ)
2GB DDR2 (800 MHZ)
nvidia 9600GT 512 MB gpu
WD 80GB and 500GB HDD
Cooler Master 600 W PSU
here is my problem from past 3 weeks;
my system is restarted after 1 or two minutes while i switch on first time. after restarting, it does not load bios. but cpu and chasis fan are run as
usual. motherboard led indicator is glowing 'green'.
my system boot normally after some time (15-30 minutes)
I have checked with standby RAM, PSU but no use. the problem still going.
later i have used the Asus PC PRobe to find the temp;
my temp is HDD is 42-45'c, cpu - 46-53, gpu 43, motherboard 43-47.
chasis has two side fans. no rear and front fans. my processor has come with med size heatsink with fan.
my pc runs fine 9 months without any heat problem.
i have also found that when motherboard temp touches 43, the above problem arised.
Now i have remove the chasis side pan and placed a table fan to maintain the motherboard temp less than 40 so that i have to use the system contineiusly.
this problem is in around Motherboard temp?
what is the best solutions ?
my config -
2GB DDR2 (800 MHZ)
